restore default block
Hello , I was using a particular EMB Inverse Real FFT.vi block . I went on to delete one of the inbuilt blocks (FFT imag block) and saved the vi. but later i found that the alteration did not help my cause . So now i want to restore the vi back to its default state. I have the same Labview version on another computer , so i made a comparison and restored the deleted array block to bring it back to its default state, but to no success.The reason being, In the block diagram of the vi, it says " This vi is a primitive for Labview DSP. The code that executes on the DSP is not directly visible, but is approximated with the windows case in the containing structure" . How can i restore the vi to its default state ? . suggestions please Mano ..
(3,279 Views)
Have you tried to repair the installation?
David_B
(3,254 Views)
Yes , i did try to repair the installation . that didn't help either . so i gave up and re-installed the entire software .. so its alrite now .. thanks .. Mano
(3,247 Views)
