restrict the movement of cursors on xy graph
hello.
I have an XY graph, with values of 0-10 in X, and of 0-10 in Y. I have two cursors in the graph.
I do not want the cursor is out of the graph area of 10 * 10, I disabled the auto scale, but the cursor can get out of the area of 10 * 10.
I also hope that the value of X of the cursor0 does not exceed the value of X of the cursor1.
I hope you can help me with these restrictions on movement, thank you very much.
(3,100 Views)
Right click on the graph and unselect Advanced>Cursors Scroll Graph.
(3,096 Views)
that's excellent, thank you.
Now I only need restrict that the value of X of the cursor0 does not exceed the value of X of the cursor1 when moving the cursors.
(3,090 Views)
Hey there, If you want to restrict the value of the cursors you can use property nodes to do so..
Here is an example; you just need to get the value on X of the active cursor (0 or 1) and then compare those values; if the value is smaller; you can use a case structure and a property node to coerce the values.
Hope this info helps.
Greetings
(3,053 Views)
If your UI is using an event structure (of course it is, right?), you can register for various cursor grab/move/release events on the XY graph.  That way you don't have to poll for where the cursors are all the time.
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
(3,037 Views)
