retrieve OS folder path
I need to know the installed OS folder path.
To my knowledge, I have to use some API function using call library.
Currently, Labwindows and any other NI product(toolkits) are available from NI full development package.
Is there some useful information(book or source code) on window API programming within any other NI products?
Thank you in advance.
메시지가 08-22-2007 03:50 PM에 labmaster에 의해 편집되었음
(3,990 Views)
The function you want is included in lvwutil.zip. You can search the developer zone for it's location.
The most comprehensive information on the windows api is on MSDN.
(3,973 Views)
You can read environment variables in labview.
%SystemDrive% C:
%SystemRoot% C:\WINNT
C:\WINDOWS
%WinDir% C:\WINNT
C:\WINDOWS
%SystemDirectory% C:\WINNT\System32
C:\WINDOWS\System32
%ComSpec% C:\WINNT\system32\cmd.exe
%programfiles% C:\WINNT\Program Files
%Temp% C:\DOCUME~1\Usr\LOCALS~1\Temp from
C:\Documents and Settings\Usr\Local Settings\Temp
%Tmp%
%HOMEDRIVE% C: The drive letter associated with the user's home directory
%HOMEPATH% The path to the user's home directory (excluding drive):
\Documents and Settings\Guest
%OS% Windows_NT (even on Windows XP machines
The operating system the user is running
%USERDOMAIN% The name of the domain that contains the user's account
%USERNAME% The user's name
%USERPROFILE%
%USERPROFILE%\Desktop
The user's desktop folder
(3,965 Views)
another method... lv 8.2
Paul
(3,956 Views)
