retrieve sound card settings
Is there a way to read the sound card settings - sample rate, no. of bits, etc?
(3,536 Views)
Joemara,
It seems that LabVIEW is very capable of configuring a sound card (Sound Input Configure.vi).  However, there is no VI in LabVIEW that can go out and get the settings of your card. I would guess that this could be done by calling a .dll with such functionality.
Charlie M. CLD
(3,512 Views)
Thanks Charlie.
It looks like winmm.dll has some of the functions I need. So I could use the call library function node to access the dll functions. However, as I am not an expert in windows programming, I do not know where to find the parameters for the function prototypes. What is the best to figure this out?
Joemar
(3,501 Views)
http://svn.dsource.org/projects/bindings/trunk/win32/mmsystem.d
contains function prototypes, enums and structure definitions.  It does not look like you are gonna have fun with this just skimming it.
You may get lucky and try using tools-->Import-->shared library and use the above file as the header.  It may work. I doubt it... but worth a try.
BTW, I found this file from:
http://forums.microsoft.com/MSDN/ShowPost.aspx?PostID=1119369&SiteID=1
Paul
(3,500 Views)
Thanks Stradis,
I tried your suggection but it did not work. I found this:
http://msdn2.microsoft.com/en-us/library/ms713750.aspx
I added hwo and pdwrate parameters but dont know how to proceed.
Joemar
(3,487 Views)
Hi Joemar.
As far as I know winmm.dll does not support getting this information from LabVIEW directly.
Your approach to use waveOutGetPlaybackRate cannot work without having called waveOutOpen before. Bad luck: waveOutOpen requires the specification of the format you want to playback ... So you won't get the results that you intended this way ...
If you are a skilled DLL programmer (in text-based languages) you might dive into MS's mixer API and write/code your wrapper.
Maybe, you find a LabVIEW-compatible mixer.dll on the shareware market. (If you find a freeware -> Let me know.)
Hope this helps, Guenter
(3,479 Views)
