retrieving data from excel using DDE
hello,
   i am just doing a project in labview. since i am new to this labview, i want to know how to extract or retrieve data from microsoft excel using Dynamic Data Exchange in labview. if any one know about this or having an example code please inform immediately.
with regards
sarguru
(3,941 Views)
sarguru,
Do you _have_to_ use DDE?  DDE is old and slow and not reliable.  Using the ActiveX interface would be a better option.  Check out the ExcelExamples.llb under examples folder in LabVIEW.
-Khalid
(3,936 Views)
hello khalid,
 its necessary for me to use DDE for this project and i didnt find ana example code to read data from excel file (using DDE also). i have a code for writing excel data using DDE. i will attach the code in this reply so that you can help me to change the code for reading the excel data.
-sarguru
(3,932 Views)
You will have to use the Advise VIs for reading data.  Look at the examples which ship with LabVIEW:
examples\comm\ddeexamp.llb
Especially the Advise Client.VI.
-Khalid
Message Edited by Khalid on 10-24-2005 02:07 AM
(3,925 Views)
