retrieving icon from resource
Hi all,
I'm trying to retreive an icon from the resource section of user32.dll, but I don't know how I would code that in LV 7.0.  Any ideas?
Adrian
Message 1 of 13
(4,892 Views)
Hey!
I'm not exactly sure about what you trying to perform, but:
If it is possible to retrieve an icon from user32.dll methods or properties, just use a call library function node in LabVIEW to access the DLL and get the icon information. Depending on the information (datatyp, structure, ...) and depending an what you want to do with it (save it, use it in LV) you maybe have to use other functions to convert the date in the required format.
BR, Chrisitan
Message 2 of 13
(4,869 Views)
try the Freeware tool ResHack, it supports command line scripting. So you can get access via the ShellExecute.
greets, Dave
Greets, Dave
Message 3 of 13
(4,861 Views)
greets, Dave
Thanks dave, but I'd like to load it in programaticly so if the icon is changed in the next revision of windows, the new look of the application will be consistent with that OS.
Adrian
Message 4 of 13
(4,842 Views)
@Christian_M wrote:
Hey!
BR, Chrisitan
Hi Christian,
I've had difficulty with just getting icons from within C/C++, never mind LV.  Does anyone have a code snippet that they would like to share?  If so, please save it as a LV 7.0 file, we haven't upgraded yet.
Thanks a lot everyone.
Adrian
Message 5 of 13
(4,840 Views)
Oh, just to let eveyone know what I am attempting to do, I'd like to load in an icon from the user32.dll file and programaticly get it to show up on a button when in the 'true' state.
Anyone every attempt this before?
Adrian
Message 6 of 13
(4,838 Views)
Hey!
If you could provide me with a little bit of information of which function to call and which parameters to set please.
BR, Christian
Message 7 of 13
(4,831 Views)
@Christian_M wrote:
Hey!
BR, Christian
That is what I'm trying to find out. 😞
Adrian
Message 8 of 13
(4,785 Views)
as I wrote in my last post, there is a way to get access to icon ressources via ResHacker. Additionally it is necessary to have IrfanView (Freeware) installed. If this is done, ResHacker.exe has to be in the same directory as the LLB. Then it should work.
greets, Dave
Greets, Dave
Message 9 of 13
(4,712 Views)
greets, Dave
Ah, great.  I looked at the web page and didn't see any reference to LV so I figured you were saying to use that app to capture the icon and then paste it in to my app.
Thanks for the help.  I'll look into the .llb.
Adrian
Message 10 of 13
(4,671 Views)
