retriggerable & synchronization examples removed?
While reading this white paper about retriggerable tasks ( https://www.ni.com/en/support/documentation/supplemental/21/retriggerable-tasks-in-ni-daqmx.html ) and I see toward the bottom this note: "NI-DAQmx versions 9.5.5 and newer do not include retriggerable examples for LabVIEW 2012." Indeed when I look in the example finder in 2012, I can see the many of the examples that were included in 2011 ( https://forums.ni.com/t5/NI-DAQmx-Examples/Index-of-DAQmx-Shipping-Examples-2011-and-previous/td-p/3... ) are not available to me. It has been quite frustrating to me that documentation on NI.com constantly refers to examples in the Example FInder that are not present.
I am wondering why the examples were removed. Are the practices they describe not recommended or not compatible? Is there an alternative method I should be using instead?
(2,345 Views)
fborlc,
I'm not 100%, but I believe the examples were removed because they are not compatabile with a number of cards (including M series).  The examples are still accessible at the link you cited.
James K.
(2,325 Views)
