retrocompatibility
I developed a software using lv8. Now I have to run this on a machine with lv7.1.
Can I impose to lv8 any retrocompatibility for that file?
Many thanks! 🙂
(4,211 Views)
Use File/Save for Previous Version to save it so it is saved at 7.1.
Of course if you have used features that are unique to 8.0, then 7.1 won't be able to execute it.
(4,200 Views)
thanks a lot! I found it... 🙂
(4,180 Views)
I have the same problem but I can't choose 7.1 version : I only have 8 or 8.2 and there are no specifics stuff of the 8 version in my VI... Is there any way to do it? (I use a student version)
(4,089 Views)
You can only save for one version previous to the one you're using. So if you have 8.2, you can only save for 8.0. You would need a copy of 8.0 in order to save it for 7.1.
(4,075 Views)
Ok thx for the answer even if I have to do my prog on 7.1 version now 🙂
I think that something NI could improve : if a 8.2 can save as 8.0 and 8.0 as 7.1 why can't we do 8.2 to 7.1 directly(even Microsoft managed to do it :))... I don't think that it would be that hard...
Well I hope it will be in the next upgrade
Message Edité par Gipada le 12-19-2006 04:18 PM
(4,071 Views)
