return from subVI
Norbert,
       I just found something quite interesting!  I am using an event handler in subVI A to catch when B is called.  To test whether execution was returning to "A" I created a 500ms timeout in my event handler and added a indicator on the loop index.  I found that the index IS incrementing, so the event handler is executing upon return from B, but somehow I still do not have the ability to interact with the UI.  HMMMM.  I still don't have a solution but I thought it was interesting nonetheless.
~goldie
Message 11 of 14
(967 Views)
Goldie,
in your SubVI B, do you use any third party applications, like ActiveX-Servers, DLLs or exe?
I believe that the OS changes task, but since the UI from the task is hidden (or something like that), it cannot visually reflect that. Your Sub B works on like it should, but since LV does not have the focus from the OS, it cannot give Sub A the focus in regard to interaction. Why the bar reflects "active", i cannot explain.
If you are running in such an issue, you can use the Windows SDK to set the focus back to your LV-application.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 12 of 14
(947 Views)
No I am not running anything other than a front panel in Sub B.  To make it even worse, I can move the window location of "Sub A" when it returns but I still have no functionality on the front panel.
I finally solved the problem, after way to many hours of troubleshooting.  I went back to a previous version of my Sub A, put in the links to Sub B with the simple Vi in an event structure and everything works as planned.  Who knows??
Thanks for your time and for bouncing ideas back and forth.
~goldie
Message 13 of 14
(931 Views)
Goldie,
good to know that you found a working solution to your issue 🙂
Nevertheless, i thought of somthing what could be a better solution for the future. This is maybe one of the best ways to display different sub VIs in a main: Subpanelcontrol.
If you havent heared about this, there is a good example provided with LV....
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 14 of 14
(913 Views)
