returning an array of 0s and 1s according to the waveform detected
I hope someone can help with this issue. I'm still new to Labview and hope someone can help create this code.
I have a device (single photon detector) that generates a pulse (5V) if it detects a photon, and no pulse if there is no photon. The rate of these pulses would be 5kHz max.
The code should work as follow: if a 5V pulse is detected, it should return 1, if no pulse is detected, should return zero. Then an array of zeros and ones will be created.
I'm reading from the single-photon detector using a DAC device (PCI-5122), which is also triggered. So the code should work only when it receives a trigger, which is at a frequency of 5kHz. The code should not miss any of these pulses.
Any help?
Thanks in advance.
(1,439 Views)
What do you have so far?
(1,437 Views)
Hi MK,
Suggestion:
IF voltage >= 4.0     % whatever limit is suitable to you
THEN
  output "1"
ELSE
  output "0"
ENDIF
Hint: never compare for "==5" when you deal with real-world analog measurements…
(1,432 Views)
so far i'm using the vi example code in order to display the waveform, it can be found under  Hardware Input and Output»Modular Instruments»NISCOPE (High-Speed Digitizers)»Demos»niScope EX Quick Start.vi
I believe since the waveform can be shown, then i can do some analysis on it. But i'm not sure how to do it. The waveform displayed is of the format cluster waveform.
(1,392 Views)
Hi Gerd,
thanks for the suggestion. That's what i'm planning to do, but how to do this is what i'm struggling with, especially since the code i'm using (Hardware Input and Output»Modular Instruments»NISCOPE (High-Speed Digitizers)»Demos»niScope EX Quick Start.vi.) gives the waveform as a cluster format.
How to return an array after analyzing each waveform one by one and that can be displayed and saved later?
(1,388 Views)
Hi MK,
Quite easily:
(1,374 Views)
