reverb.pan.vi
Hi
I had a problem with implementing the echo effect  on speedy33,and then I received the reverberation VI file but some reverb.pan.vi file was missing. where would I find this file.
(2,424 Views)
Hi, I guess the vi that you are talking about will be some subvi. Can you please be more specific as to what is the error code that you are getting so that I can help you better. Also I have attached here a link for an example code called Reverb.VI See if it helps. http://zone.ni.com/devzone/cda/epd/p/id/1797 But we will need more information to help you better. Thank You. Priyank
(2,400 Views)
