reverse order of concatenated string
As above,
I have used the concatenate strings function. Is there was to reverse the order of the strings before I output them as a message to the user, as the information is in reverse order??
Message 1 of 8
(6,356 Views)
Hi richard,
as it's not entirely clear, what you are looking for: either change the order of the input strings at the ConcatString function or use the ReverseString function…
Message 2 of 8
(6,344 Views)
what is your mean reverse
reverse action or
reverse string
Message 3 of 8
(6,336 Views)
@lvrichard wrote:
As above,
I am not sure what you want, so only pure guessing: you might consider using a string array to keep the messages at separated array indexes. In this way you can easily change oder of msgs by the simple array functions...
Message 4 of 8
(6,331 Views)
@lvrichard wrote:
As above,
Why not concatenate the strings in the right order to begin with instead of concatenateing them and then trying to reverse the concatenate order?
=== Engineer Ambiguously ===
Message 5 of 8
(6,268 Views)
I'm sure there are many ways to do this. If you have words in your message, and you want to reverse the order of the words, you can search search for all of the spaces and get an array of all the words. Then reverse the array and add the spaces back in. It will be very similar if your words are separated by new lines.
Edit: And Altenbach will post something with only 2 block diagram nodes in 3... 2... 1...
Message 6 of 8
(6,252 Views)
(I have not found better)
Message 7 of 8
(6,218 Views)
Another solution using regex.
Ben64
Message 8 of 8
(6,182 Views)
