reverse update table
Hi, i want my vi to update values in an table reversely. what i mean is currently old results go below current ones. i want old values to go above current ones. How can i do this?
Stu
(5,057 Views)
Hi Stu,
simply switch the inputs of the BuildArray node...
(5,047 Views)
Hey stu22,
I will kindly suggest you to post the screenshots of VI unless there is some complex issue/logic inside complete VI you can't figure out .. This will help us in writing quick ans..
I expect there are many users who are using other smart and portable devices for blogging and don't have LabVIEW installed on it ..
HS
(5,045 Views)
Hi, thanks for that. Forgot to say is posible to keep the focus on the most recent values as they disappear when they get towards the end of the table.
Stu
(5,028 Views)
As u can't see your VI but from your two post on requirement .. i can hint some thing like this in post http://forums.ni.com/t5/LabVIEW/string-append-scroll-up/m-p/1140437
it may not be exactly what you need but can certainly help in logic.. Rest if you can post screenshot then would be nice..
(5,020 Views)
Yeah, this is what i want. Thanks 😄 now which one of you wants the kudos lol
(5,009 Views)
Kudos are always welcome Smiley Wink
(4,995 Views)
