reversing the voltage source
hello,
below is the program i am working on,which sources the voltage from 1vto -1v.
i want to reverse it(i.e. -1v to 1v)
please help me where should i do the modification without much hassle.
thanks
(2,590 Views)
Hi jyot,
Clean up. Really.
which sources the voltage from 1vto -1v. i want to reverse it(i.e. -1v to 1v)
Just swap the values for "initial voltage" and "final voltage" and negate the difference…
(Hint: Use the Ramp function to create an array of voltage setpoints and autoindex it with your FOR loop. No need to do calculation in the loop.)
Btw. SI unit for voltages is a capital V.
(2,575 Views)
@GerdW wrote:
Hi jyot,
Clean up. Really.
As long as we're on the topic of formatting with SI units, the value should be separated from the unit with a space.  e.g., 1.5 MHz.
Bill
CLD
(Mid-Level minion.)
(2,540 Views)
