rgb statistics of an 24bit bitmap
Hello
I try to analyse the RGB values (max, min, mean, ect) of a 24bit bmp. i found a way to represent the pixelvalues as 24bit values in an array.
then i convertet the array into a dynamic signal. since the 24bit consists of 3 Bytes which represent the values of each rgb-channel i need to splitt this 24 bit into bytes. I found a VI vich changes the color format into rgb. the problem now is that the resulting values are single scalar which i really cant analyse with the signal analysing tool. i always get the same values for mx, min and mean, that means only one scalar value ist analysed.
How can i achive that the whole 2bit signal is splittet into byte-pieces in signal form?
can somebody help me?
Thank you very much!
Simon
Using Labview 7.1
(2,890 Views)
Hi Simon,
maybe you can stick to your RGB data without converting to 'dynamic signal'. Just have a look at the attached vi, it's just pure arithmetic to get the color channels.
Other simple method would be to put 'Color to RGB' into 2 auto-indexing for-loops (without conversion to dynamic in front) to split the color channels.
Message Edited by GerdW on 08-01-2006 01:57 PM
(2,889 Views)
Yes it works! thank you very much!
Using Labview 7.1
(2,881 Views)
