right click option disabled in LabVIEW through Radmin Viewer based remote PC access
 hi all,
i'm remotely accesing a test station with LabVIEW 2010 SP1 and this system is located in USA.
i'm using Radmin viewer 3 for this remote access and facing below issues:
1. Not able to click on any list controls/ring controls/enum control etc on Front panel and not able to see the list of cases on block diagram case structure/ event structure etc. Not as a list but but can sequentially traverse through the cases. same thing on front panel.
2. Not able to right click on front panel and block diagram and use breakpoint debug options.
otherwise running the VI is not a proble. and other appliocations except LabVIEW are fine with Radmin Viewer for the right click option.
have you any suggestions how I can resolve this or any other free software I can use for remote access?
thanks in advance...
(2,774 Views)
That sounds like an issue with Radmin.
I'm a big fan of LogMeIn (the free version) ... http://www.logmein.com
But have also used RealVNC ... http://www.realvnc.com/
http://www.medicollector.com
(2,759 Views)
hi, thanks for the options:
i've used VNC Viewer application (i'm not sure if the VNC you suggested is the same)- but still not able to view the vertical list of cases on case structure, event structure etc.
i'll try logmein option and check this.
thanks.
(2,753 Views)
