11-02-2004 01:49 PM
 kimdino
			kimdino
			01-05-2007 10:31 AM
 Ray.R
			Ray.R
			01-05-2007 11:51 AM
Hello all...
I'm just curious... 3 different people reporting the same behavior in the same timeframe (or relatively...)
This is too odd to be a mere coincidence.. Can you all provide some info such as what OS you are using? If using MS-Windoze, do you have automatic upgrades turned ON?
There has to be something that triggered this bizzare situation. I still use LV7.0 & LV7.1 for some customers. They both run fine on XP with SP-2.
I'm definitely interested in finding out what triggers this behavior and would suspect that there is nothing wrong with the LV installation, especially if it was running fine up to this point.
Thanks for posting this issue... It's good to know what others are seeing in order to avoid lengthy debugging processes.. 😮
JLV
