rnrz scrambler
 I need to implement the small circuit attached as a slide. I am able to implement the circuit with a 1 bit input and a 1 bit output, in a crude fashion (using 15 shift registers and 15 feedback nodes) which I am not happy with. Also,I want to input a boolean array and get a boolean array as output. Any ideas please???
(2,660 Views)
Hey,
I have reached somewhere with the code, but there is still some problem, its not giving the desired result
(2,635 Views)
It would be helpful if you were specific about what the desired result should be. Also you did not save the VI with any default data, so we do not know what your input is either.
I cannot open your slide.  Create a .png file and attach it or insert the image into your post.
Lynn
(2,623 Views)
