roboRIO Won't Load Due to Errors 7 & 1026
We are a FRC team and we are attempting to deploy code through LabVIEW onto the FRC Driver Station. After loading the robot code in LabVIEW and getting green lights for the Rio communication and robot code, it sends error messages 7 and 1026. Error 7 only appears in the Driver Station when the robot is enabled.
ERROR 1026 Property Node in FPGA_SystemAsync VI Agent.viLabVIEW: (Hex 0x402) VI Reference is invalid.
ERROR 7 Call Library Function Node in CTRE_Phoenix_MotorControl_Set.vi:5580001->Teleop.vi->Robot.Main.viLabVIEW: (Hex 0x7) File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
We don't have anyone with any programming knowledge on our team so any help is greatly appreciated. Thanks.
(2,175 Views)
I would re-image the roboRIO with the latest image. I don't think your roboRIO is configured properly.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,167 Views)
