robotic arm
Dear all,
We are testing an USB based Smart Card Reader which involves thousands of smart cards to be placed in the reader one by one for testing. Since manually its a tedious process, we are trying to automate the application. Basically what we thought of was purchasing a robotic arm.
Using a robotic arm to pick up a smart card reader from one tray, place it on the reader exactly, after testing it will pick it up and place it on one tray if the test was passed, and put it in another tray, if the test fails.
Any idea of how to implement this? Will NI had such robotic arm and software for control.
Mathan
(4,549 Views)
Hi mathan,
you can use something like this http://www.kuka.com/en/products/industrial_robots/small_robots/kr5_sixx_r650/start.htm Smiley Wink I´m sure you can control it with LabVIEW.
Mike
(4,548 Views)
We use ABB robots and are pretty happy with them. Surely you want to test more than one device at a time. I would check the internet for some sort of test fixture hardware that will check a dozen or more at a time. You may want to use a card extender than can be replaced when it gets worn out.
(4,524 Views)
you can probably get a CRS robot model A255 that would work for your application
for the labview control ,
http://www.robotsdotcom.com/
(4,516 Views)
Dear all,
Thanks for all of your valuable suggestions. This is the first time in our company that we are going to use robots for automation testing. We need to look into cost-effective, simple handling, robust and some more major factors. Anyhow all your suggestions are worth enough.
Mathan
(4,504 Views)
robotdotcom.com  look for a A255 or A465
CRS also design the KR5 For Kuka Robotics (previously KR3) etc
Kuka is  the first link you got....
those are the best small size robot!!!
(4,502 Views)
