robotics upload data
I have a robotics test kit 2.0 which I have programed to remotely (unteathered) move and record its movements. How do I retrieve the data?
thanks
(3,205 Views)
How is the data stored?
Where is the data stored?
How can you communicate with the robot?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,184 Views)
open a file,  store data, close a file   but it will have to be done on the sbrio card,
then data retrieved somehow, if I hook up the cable will it be recognized or do I need to turn off the bot which will cause everything to be reset?
store data to the serial port? with a usb converter cable to plug in a usb flash drive?
then when I want to see data remove flash drive and can look at any computer?  That sound like an idea?
thanks,
(3,171 Views)
