robotics
I am located in a highschool and usinhg the Robotics starter kit with the 2010 robotics module. Each time that we attempt to deploy code to the robot, we get a "C++ Runtime error. This application has requested runtime to terminate in an unusaul way. Please contact the application support team for more information."
This only happens with the school computers. Any help out there?
(3,115 Views)
Hi jdojr,
I have seen a few C++ runtime errors before however there could be multiple causes and multiple errors. Could you possibly get a screenshot of the C++ runtime error just so we can see exactly what error is ocurring?
Ben B.
National Instruments UK & Ireland
"I've looked into the reset button, the science is impossible!"
(3,090 Views)
I can't get a screenshot but the wording of the error is
Microsoft Visual C++ Runtime Library
Runtime error
      Labview 2010.exe
This application has requested the Runtime to terminate it in an unusaul way.
Contact the application support engineer
(3,051 Views)
Hi jdojr,
Thanks for your reply.
Have you made sure that the firewall on the computers allows LabVIEW 2010.exe? Its seems strange that this only happens when trying to deploy to the robot. Its possible the firewall is blocking communications which then crashes LabVIEW. What firewall are you using with the school computers?
Ben B.
(3,027 Views)
