robotics
Can you get me a part list of NI labview items needed to use with 2 STX-115-07-CK-HK-CDH
Copley Controls STX AC Stepnet drive controller. Screw terminal breakout board for 26-
pin I/O connections. 1 00241-8 Kvaser Leaf Light HS USB to CAN converter for LABVIEW control of stepper drives from PC.
We are making an automated moving platform for moving our design parts from one cold bath to
another hot bath to do temp response testing in less than 5 seconds and take 20 Analog measurements 0V to
5VDC of our 20 devices and 20 resistance measurements (10k Ohms) of the devices thermistors at -40C
to 150C.
(2,955 Views)
Sounds like an interesting project.  You probably should go through your NI sales rep or an FAE to get a fast response with this.  Find them at ni.com at this link http://www.ni.com/niglobal/.  Just drill down until you get the region you are in.  They will happily help you identify the components you need and can even get a quote for you.
Wire Warrior
Behold the power of LabVIEW as my army of Roomba minions streaks across the floor!
(2,942 Views)
