robotics
First, we are encountering error 74 when we try to run our program from the computer connected to the NXT. We have been trying to found out about error 74 without much luck.
While tethered, all the components in our robot work, but the schematic and the controller do not match.  Untethered, only the wheels function and we can't get the lift mechanism to work at all.  When we try to connect to the FIRST Tech Challenge field, when it goes into teleop mode, the computer says that it doesn't have a teleop program working.
Thank you in advance for your time. My team appreciates any help you can provide.
(3,354 Views)
This isn't the correct board for FIRST questions. Please see https://decibel.ni.com/content/docs/DOC-2651.
(3,344 Views)
Thank you so much for your help!
(3,335 Views)
