rolling 2D array with a max size
It would be useful to know what kind of "statistics" is actually performed on the data. For many (mean, variance, etc.), The result can be obtained by only maintaining one (or very few) scalars for each channel. For the mean, all you need is accumulate the sum, then divide by N.
Message 11 of 18
(1,578 Views)
Thanks for the ideas i will try them on monday when im back.
as for the statistics required, i am still waiting for confirmation on this but i think it is just standard deviation across each channel, then that result is compared across all data samples as well as the mean and the mean of means.  i already have the code to perform these calculations well on a 16 x 64 dataset, so i was going to tweak that code to work with 32 x 64
Message 12 of 18
(1,563 Views)
A fixed size lossy queue ?
Ben
Message 13 of 18
(1,556 Views)
To get you started, here's an old example how do do a mean and standard deviation, by only accumulating a few scalar sums.
(For the mean and standard deviation, all you need is three values: N, Sum(x), Sum(x²) for each channel. Your N is fixed if you only do the statistics on a full set. In terms of resources, this takes only a very small percentage compared to keeping all points around. In your case (several channels), you'll need a very small 2D array).
Message 14 of 18
(1,552 Views)
Here you can see that keeping only a few sums (x, x²) allows calculating the same result with 64x less data in the shift register (in the case of 128 scans) . A: Keeping all data, B: Keeping a few sums.
(This uses the "sample standard deviation"> Modify as needed if you want "population SD" instead.)
Message 15 of 18
(1,545 Views)
Here's how the efficient version could look like....
Message 16 of 18
(1,518 Views)
thanks,
I will bear this in mind should i have issues with the existing code i have. i am still waiting for fully documented spec that tells me what calculations are required.so i am reluctant to implement anything until i know for sure.
Message 17 of 18
(1,491 Views)
No problem. I am just putting it out there for the general readership. For larger histories (e.g. 1M+) the memory and resource savings would be gigantic. Similar algorithms exist for other statistical terms, of course. 🙂
Message 18 of 18
(1,473 Views)
