rotate caption programmatically
Is there a way of rotating a caption programmatically in LabVIEW 7.0?  Any help on this would be greatly appreciated.
Sanks.
Message 1 of 8
(5,818 Views)
If memory serves me correctly, the only way to get that effect in LV 7.0 was to use a picture control instead of the cation and to use the "draw Text at point"
Ben
Message 2 of 8
(5,812 Views)
If you click on the control or indicator and create a property node you can select the caption position like in the following picture.
Tim
GHSP
Message 3 of 8
(5,804 Views)
aeastet's solution will allow you to set the position of the caption, but not the angle of rotation.
I just looked in LV 8.6 and saw no properties for angle, so it appears you still need to use create a separate picture control as Ben suggested...
Message Edited by Phillip Brooks on 10-09-2008 04:27 PM
Message 4 of 8
(5,787 Views)
One possibility could be using a rotated font (of unispaced kind) and put linefeeds between all characters.
Felix
Message 5 of 8
(5,759 Views)
Hi aeastet,
Looks like "Vertical Arrangement" might be what I am looking for, but given the Icon, it looks like you are using LV 8.x.  Thanks anyway.
Message Edited by Been bitten by LabVIEW on 10-10-2008 09:22 AM
Message 6 of 8
(5,738 Views)
Thanks F. Schubert,
But not what I'm looking for.  Want to auto replace Text decorations with a control that I can give a label to.  Thanks anyway.
Message 7 of 8
(5,734 Views)
Thanks Ben, quite the PITA. 😞  I will have to determine if I want to use this. Thanks again.
Adrian
Message 8 of 8
(5,731 Views)
