round to #.5
Hi
how can I round a value to #.5-steps? that means 1.1 will be 1.0, 1.3 will be 1.5, 1.7 too and 1.8 will be 2.0.
do I really have to do this with cases?
Message 1 of 15
(4,414 Views)
This is primitive but it works.
You may have to change its threshold levels.
Regards
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 2 of 15
(4,414 Views)
Multiply your number by two, round it to the nearest integer, and divide it
by two.
Wiebe.
e.g.
1.1 * 2 => 2.2
rnd(2.2) => 2.0
2 / 2 => 1.0
1.3 * 2 => 2.6
rnd(2.6) => 3.0
3 / 2 => 1.5
1.8 * 2 => 3.6
rnd(3.6) => 4.0
4 /2 => 2.0
"Yves" wrote in message
news:5065000000080000003A600000-1031838699000@exchange.ni.com...
> Hi
Message 3 of 15
(4,414 Views)
BRILLIANT & COOL !
I like it!
Ian F
依恩与LabVIEW
Message 4 of 15
(4,414 Views)
this is great. I created a quite complicated subvi, which is working too, but I will replace it with your routine.
thanks
yves
Message 5 of 15
(4,414 Views)
I just found a problem: the value #.25 doesn't work! the vaule is rounded to #.0.
any solution?
Message 6 of 15
(4,414 Views)
Yves,
This is caused by the definition of rounding from LabVIEW:
The int() / Round To Nearest function does this:
Rounds the input to the nearest integer. If the value of the input is midway
between two integers (for example, 1.5 or 2.5), the function returns the
nearest even integer (2).
So:
int(1.4999999999) => 1
int(1.5000000000) => 2
int(2.4999999999) => 2
int(2.5000000000) => 2 !!!
This is exactly accoring the rules (IEEE 754)! Read about the rules in:
http://http.cs.berkeley.edu/~wkahan/ieee754status/IEEE754.PDF
It is like this to prevent rounding bias.
Wiebe.
news:506500000005000000D9A80000-1031838699000@exchange.ni.com...
e vaule is
> rounded to #.0.
> any solution?
Message 7 of 15
(4,414 Views)
thanks for your very competent answer. I just studied the rules you described. this is in fact very odd.
because of that I created a subvi which gives out the correct values.
Message 8 of 15
(4,414 Views)
hi, would you kindly save it to earlier version as well? for instant, LV6i
So that those who are using LV version earlier than 6.1 could use it too.
Thanks and regards
Ian F
依恩与LabVIEW
Message 9 of 15
(4,414 Views)
Message 10 of 15
(4,414 Views)
