rounding question
In this experimental VI, I do a number of conversions, etc.  I'm wondering why, when I input 327.63 as my numeric, I see 327.62 at the end of my concatenated string.
(3,046 Views)
You are throwing away data by retaining only 3 elements with the array subset operation. To get the right result, you need a length of four. Try it.
(3,041 Views)
In particular, you are left with 327.625, which according to the bankers rounding is rounded to the even number, or 327.62 in this case.
(3,037 Views)
I think  I confused the ArraySubset with another utility where you provide the first/last indexes into the array.  Thanks.
(3,001 Views)
