rows with different background color in array
I am displaying an array indicator. When certain values are found in a row of the array, I would like the row to have a different background color so that it stands out on the front panel. Can this be done? Especially, can this be done using property nodes dynamically?
Thank you
(2,887 Views)
Hi jmaarek,
I don't think you can do this with arrays as all the elements have the same properties.
You can do this with a table though. Use the 'Active Cell' property (set the row to -2 to select the entire row) and the 'CellBGColor' property.
Hope this helps.
(2,875 Views)
