rs 232 communication
is it possible to read and write 8 bit string from pc to custom card reading
and writing every single bit?
thanks
david
(3,788 Views)
You can do a lot of things. I'm not sure what a custom card has to do with rs232, but included with LabVIEW are the VIs called INPORT and OUTPORT. These will send/receive data at any I/O base. So if you know what I/O base your card is at, you can send to it and receive from it.
Rob
(3,788 Views)
thanks for the answer.
my custom card read and write with a rs 232 port.
are you talking about visa controls?
"david" ha scritto nel messaggio
news:a65fto$kdt$1@news.flashnet.it...
reading
> thanks
> david
(3,788 Views)
Hallo, david,
Du (david) meintest am 06.03.02:
Does it use the v24/rs232 protocol, or does it only use a Sub-D9
connector?
Greetings!
Helmut
Please excuse my gerlish!
(3,788 Views)
LabVIEW is a handy development tool if you want to control/read-out serial RS-232 devices. In my compact company custom (RS-232) hardware is developed, so I communicate via this bus a lot.
In the beginning of LabVIEW one only had the serial I/O vi's. Although after some years VISA was introduced as a better solution for communications, the plain old serial vi's still work well for a lot of demanding users. The choice is up to you.
(3,788 Views)
