rs 232 communication
i must read and write data and command from a custom card with a labview vi.
can someone send me documentation or example of serial communication
protocol that can be implemented in labview?
thanks.
david
(3,423 Views)
Good examples of drivers to support RS-232 devices can be found on this site.
If you bought the card, you can ask the supplier for the protocol/command set.
If it is an internally developed device (we do that frequently) the complexity/robustness of the protocol will depend on what the task of the device is (and under what conditions, lab is quite different from plan-operation). And as long as this will not be sold as an open commercial system to the outside world, you can use your own protocol. Sorry, have no example.
(3,423 Views)
in what site can i search example of rs 232 communication protocols or
drivers ?
david.
"PdB_Serenity_nl" ha scritto nel messaggio
news:506500000005000000BD650000-1012609683000@exchange.ni.com...
> this site.
(3,423 Views)
Hallo, news,
Du (david) meintest am 11.03.02:
> communication protocol that can be implemented in labview?
You should have seen the examples ...
Is there any example which you can adopt for your problem?
Greetings!
Helmut
Please excuse my gerlish!
(3,423 Views)
The following link is to NI's 'Serial Communication Starting Point' webpage:
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/bdb91a0aa309c1a486256821000685e5?OpenDocument
If you need more detailed information you might try perusing google.com, etc.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(3,423 Views)
