rs 232 dual commnunication
I have the following problem.
I've build an analog voltage regulator ( http://www.circuitsonline.net/schakelingen/71/voedingen/labvoeding.html) and I want to replace the potentiometers for digital ones. If that is done I want to let it communicate via rs232 so that I can regulate the voltage and amps. Beside that I want to see on my comuterscreen what the voltages an amps are.
How can I do that? How does the software work? And what do i need for hardware (selfmade, not an fpga module or something like that).
Jorim
(2,956 Views)
If you want to measure the voltage and current you need ADC 😉
The cheap and easy way is an µC of your choice with adc and uart , add a ttl3rs232 chip (like max232).
Without µC programming: use the RS232 flow control lines to bitbang something like a I2C communication. Maybe there are dig pot and adc chips that can chained up otherwise you need 4 chip select lines and you only have 3 easy to access output lines where one is needed for clk , one is data and one for CS???? so you need another I2C port extention chip for the CSs .... and you need to write a bitbanging protocoll for the RS232 in LabVIEW using the VISA serial properties....
Or you decide to use the good old legacy printer port .....
Greetings from Germany
Henrik
LV since v3.1
(2,940 Views)
I've just reseved(???) an PIC18F2520. This pis has 2 adc's on board. Is it posible to use this one combined with an max 232? Does someone has an .hex file that I can use for an PIC ic (18f252 or an other one) If this is posible?
(2,901 Views)
Using a PIC18F2520 is a good idea. In order to get something useful out of it. You need some equipment like a programmer. You must also do the programming job your self, as almost every MCU project is unique.
By the way. For this project you will only need 1 RS232 line. Your job will be to create a protocol so you can sort out the information sent from the PIC18F2520.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,879 Views)
