09-05-2007 10:18 AM
09-05-2007 10:21 PM
A shot in the dark.
How do the settings between the two computers compare for the serial ports in Windows device manager? Is it possible the Flow control settings are different at the Windows device manager level, such as one being set for hardware control and the other not?
09-06-2007 01:57 AM
As far as i can see, all settings in the windows device manager are the same
Christine
09-07-2007 07:43 AM
Check to make sure you have a good ground reference between the laptop and the device.
I have seen ground issues with some laptops that will prevent code that runs fine on one machine to run on others.
Next:
Not all serial ports support hardware flow control. Check on that next.
If you have a good ground and the PC support hardware handshaking, then the hardware handshaking can be manipulated via property nodes, but first, verify the points above.
Ben
