RS485 addressing is not related to port setup, but it's instrument dependent. Normally the address is embedded in the command strings.
Check the instrument communication protocol documentation if you need to build it from scratch. If there is an instrument driver, there should be some address parameter to be passed to the related vi's/functions.
Paolo
Paolo
LV 7.1, 2011, 2017, 2019, 2021
