rt friend class deployment errors
Hi all,
I am seeing deployment errors on my SBRIO, when I remove the friend relation, the errors are gone?
Something I am misunderstanding here? Should it maybe not work on the SBRIO RTOS?
Roger
(2,989 Views)
Can you give some details on the extact error that you are getting?
(2,970 Views)
The same issue with static references... I'm guessing there is some difference between the dependency calculation on the windows and RT runtime? See the following images
Image 1: Normal running (main) program.
Image 2: A static vi reference added in the program (still working, no deployment errors):
Now it fails to deploy when I add a static vi reference to one of my Server_init methods in a server base class:
I tired to reproduce this on a more limited program, but I came up short.
If requested, I could provide the full program.
Roger
Message Edited by RogerI on 04-02-2010 04:25 AM
(2,966 Views)
