rt get time string pb
I face a pb concerning the time in cFP2100 ( or FP ).
I display the time ( and it's correct even for daylight ). But when I convert the time to string ( to write it in a file)
the value is not the same.
The PAC works with no PC (so without time server ) : I've configured it with UTC+1 ( Paris = GMT+1) and daylight is enabled.
Please take a look at my vi : if you can give me a way to get the time. Thank you
(4,976 Views)
Just a comment : I need to get the local time (not the UTC time) into a string.
"Format Date/time string" return the UTC time.
Is it possible ?
Thank you
(4,968 Views)
For me it works correctly. Format Date/Time String" returns either the UTC time or the local time depending on the flag. Thus I see the UTC time in one string indicator and my local time (UTC + 2, equal to the OS time) in the other.
Did you set up the time zone in windows?
EDIT: Sorry, you're not using windows. Looks like LabVIEW doesn't notice the time setting in the FP device.
Message Edited by dan_u on 03-27-2007 04:01 PM
(4,967 Views)
yes but with the dayllight it doesn't work for me.
(4,957 Views)
Please try the following test:
* configure the FP module : UTC+1 (Paris/madrid) (= Norway UTC+1)
* check the daylight box
* use the VI in the first message for making test (RT Set Date and Time)
TEST 1)
set date to 01/27/2007
set Local Time to 16:00:00
you will get
Get Date Time in seconds
1) directly displayed :                                                             15:00:00
2) displayed after "Format Date/time" with UTC flag=T :     15:00:00
3) displayed after "Format Date/time" with UTC flag=F :     16:00:00
It's correct because items 1 and 3 are same
TEST 2)
set date to 03/27/2007
you will get
1) directly displayed :                                                             17:00:00
It's not correct because I expected that item 3 was equal to item 1.
What is wrong in my configuration ?.
What is the good way to get the actual time into a string ?.
Thank you for your help
(4,939 Views)
the following VI works fine on PC but not on cFP.
Why ?
For example : I get :
"Temps actuel" 14:00
chaine date heure= 14:00               (Format Date/Time string with UTC flag=FALSE) = local time
chaine date heure 2 = 12:00         (Format Date/Time string with UTC flag=FALSE)
(4,907 Views)
I don't have FieldPoint devices, so I can't test. But anyway the easiest solution would probably be to store all data in UTC time. This will also prevent a time overlap/jump when daylight savings start/stop.
In the header of the data file you can write that times are in UTC and then they can be adjusted for displaying in local time.
(4,899 Views)
