rt launching vi dynamically
Hi all,
I am trying to launch a vi dynamically inside RT. But I am unable to do it. It either throws up error 100 (VI not in compatible state for this operation) or just I get disconnected from the RT. I am not sure about the problem and I need help in this. How do I launch a VI dynamically inside RT. All its dependencies are downloaded to RT.
The VIs I am trying to launch is a member of a class.
VIs property is set to be modal. (I want it to be front most when it gets launcheed. We are using LabVIEW Embedded UI for monitoring purposes).
I am able to get the reference of the VI porperly. The error occurs in invoke node which tries to run the VI.
Should the VI be reentrant for launching(a hunch of my own-but not sure why it should be)?
Thanks in advance for your replies.
(2,918 Views)
