rt switch to 8.20
switching to LV RT 8.2, I've got pb with the HMI wich is embedded inside the cFP2100 module using a web page
I've got 2 pbs :
* on computers with the previous version (RT 8.0) we can't display the HMI using IE : the page download stays at 0 %.
* on my computer with only RT8.2, I've got the web page BUT we need to launch the application from LV to get refresh !!!
What's wrong ?.
Thank you
(3,252 Views)
are you sure that the good labview runtine is install on each compturer?
if you don't know install both runtime on each, (8.0 &8.2)
Best Regards
Moby
(3,231 Views)
On one computer, both runtime are installed and only the 8.2 version on the other.
thank you for your answer.
(3,228 Views)
