rt
I am exercising " Getting started with LV RT manual ". I build a deterministic PID control application as in attached Second PID Control.vi but it can not be run nor downloaded to RT Target. The following list of errors is shown.
BLOCK Disgram Error
poly vi 'daqmx read.vi':subvi is not executable
poly vi 'daqmx read.vi':polymorphic subvi is broken
Please help me
regards
(5,007 Views)
Hi Zalmay,
It sounds like there is an incompatibility or corruption with the DAQmx Drivers installed on your RT target or host.  What version of the Drivers are you currently using?
Steven B.
(4,980 Views)
