run a program with system exec.vi
hi
I've got a problem with system exec.
When I launch a simple program like :  c:\windows\notepad.exe it works very well.
But when I launch a program with parameters, it doesn't.
here is the command line:   c:\bmd.exe a.bmd a.txt ffffffff ffffffff
When I put this command line in a cmd windows it works perfectly. It don't understand...
Any idea?
(3,767 Views)
Doese this work dirrectly from the command prompt? I have used parameters with suscess in the past like launching IE with parameters.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,757 Views)
Is it a DOS program you are trying to execute under Windows?
If so insert command.com /C before the command.
(3,743 Views)
Hi Julesjay,
I found out that if the command string didn't include the path of the executable (start) the program would fail (at least with matlab executables) So make sure the path of the exe is included in the command string.
Ton
My LabVIEW Ideas
(3,732 Views)
