run after start problem
i made the preference that my vi runs when i start up the vi. the window appearance is a dialog...
when i start up the vi it hangs and i couldn't return to the diagramm because i've got no menus.
how can i return to the other appearance or how can i get the labview menus back
(2,781 Views)
to open such a vi in edit mode you have to do the following things:
1. Create a new Untitled.vi and go to its diagram.
2. Place your problematic VI on this diagram as a subVI.
3. Double-click on it and it will be opened in edit mode.
Good luck.
Oleg Chutko.
(2,781 Views)
thank you!
(2,781 Views)
