run button on the front panel
Is there a way to have a run button on the front panel, instead of the little arrow on the top? I want to do an update button on the front panel, so after a change in controls is made, I have to stop and run the VI all over again.
(3,125 Views)
just imbed your whole diagram in a case statement, inside a while loop, and create a run button connected to the case input. Don't forget to add a wait function, with a moderate time value (200 ms). You could also use an event structure.
Message Edité par chilly charly le 11-01-2005 08:56 AM
Chilly Charly    (aka CC)
(3,116 Views)
