02-22-2006 05:17 PM
02-23-2006 12:44 AM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
02-23-2006 09:24 AM
Hi TiTou,
I think this is the file that is missing from the previous attachment.
Somehow this file gets lost even after I save the VI in library.
thanks for your help!
02-27-2006 04:44 PM
I tried to this subVI for initial setup for the TDS8K scope. I have modifed the subVI to include some other settings that were observed from manual setup.
Having said that, I have a couple of questions..
1. Can anyone see a problem with the attached VI?
2. The main interest is on Math channel (M1) but since M1 = C1 - C2...I think I need to set (properly) with both channels....is this the subVI where I can add such setting as "external attenuation", "scale", "position" etc...
thanks,
03-06-2006 04:26 PM
03-07-2006 02:38 PM
how can I add other event cases (i.e.'setting', 'run') in sequence, so that each event will occur sequentially.
Do I need to add additional lines with event cases??
03-07-2006 04:16 PM
03-07-2006 04:32 PM
03-08-2006 10:33 AM
03-08-2006 11:27 AM
