run endless c-dll and use GUI in parallel
I want to start a function from a c-dll in LabVIEW (that works fine) and while executing this function (it may run for
a long time), I want to collect input from the LabVIEW GUI (e.g. a change in a numeric control).
I put these two tasks in two unconnected while-loops but still, as long as the c-function is running I cannot
collect changes from the GUI (at least the changes are not shown, after the c-function has stopped, the
changes become visible).
So running the function from the c-dll completely blocks the LabView GUI. Can anyone give me a hint
how I can run these two things in parallel?
thanks,
CF
(2,526 Views)
Accepted by topic author CF333
You need to change the Call Library Function Node configuration from "Run in the UI thread" to "Run in Any Thread."  Normally this option should be used only when you know the DLL is reentrant (thread-safe).  However, if you're only running one function from the DLL and it's running continuously, it will stay in the same thread for the duration of the call so it won't matter in which thread you call it.  By allowing it to run in any thread you'll free the user interface thread to handle the user interface.
(2,517 Views)
Thank you, thank you, thank you, thank you ...
(2,508 Views)
