run exe file automatically when opened
I have built exe file of my application. I have unmarked the option RUN when Opened, because I do not want the application to run immediately. But I want to run my exe application automatically using System exec.vi. I do not want to press the run button manually.
Is this possible to do?
Br
Basil
(2,825 Views)
Hi Basil,
for an exe you should NOT unmark 'Run when opened', as this should be the expected behaviour of an executable!
If you need a 'Start' button of similar you should make this on the user interface.
So you just have to re-built your exe.
(2,820 Views)
