run labview vi upon computer startup
Is it possible to run a labview program upon start up of the computer?  I can get the program to open by putting a shortcut into the startup directory.  I'd like the program to run automatically also.
Nick
(3,061 Views)
If this was built into an EXE then it would run, if this is a VI then go into the vi properties and set it to run when opened. this should do it.
Joe.
"NOTHING IS EVER EASY"
(3,054 Views)
Thank you.  That was excatly what I needed.
(3,038 Views)
