run the same vi simultanously in one loop
Hi
I want to have the same vi running twice in one loop. the parameters are different. "both" vis should run simultanously.
how can I do that?
or is there any other solution to have the same subvi running in one loop with different parameters?
thanks for any help.
(2,521 Views)
Check out the info in the link below:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=50650000000800000056400000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=multiple+instances&USEARCHCONTEXT_QUESTION_S=0
(2,521 Views)
