run-time engine doesn't run ('network error')
I'm trying to get the RuntimeEngine 7.0 to work on my Win2K PC, which is behine a corporate firewall. The webpage is being setup at an university which I don't believe to have any access restrictions. When I try to access the data page I got the 'network error' message.
Is this because I'm behind the firewall? Is there any setting I can do to gain access?
Thanks!
(2,669 Views)
This sounds like a problem with your network setup. Have you tried running the page from a computer that is not behind the firewall? You might want to try talking with your network admin. The data for remote front panels is not wrapped in HTTP, which is probably why your firewall is rejecting the data.
(2,669 Views)
