run time engine download disabled?
Hi,  I am trying to download the lates LV run time engine.  There are pages for 8.0 and 8.2, no 8.2.1.  However, when I click on the links to download either version, the files are not there.  What's going on?
Message 1 of 11
(5,121 Views)
Go here:
ftp://ftp.ni.com/support/labview/runtime/
You'll find them there.  Assuming Windows,
8.0:  ftp://ftp.ni.com/support/labview/runtime/windows/8.0
8.2:  ftp://ftp.ni.com/support/labview/runtime/windows/8.2/8.2.0
8.2.1:  ftp://ftp.ni.com/support/labview/runtime/windows/8.2
8.5:  ftp://ftp.ni.com/support/labview/runtime/windows/8.5
Message 2 of 11
(5,116 Views)
Hi mrsharkbait,
You can go to the drivers and updates page at https://www.ni.com/en/support/downloads.html and search for keyword "runtime engine", which will return pages from where you can download the runtime engines, or go to this page https://www.ni.com/en/support/downloads/software-products/download.labview-runtime.html
I just tried this and it works. How did you get to the pages where runtime engine download is disabled? Maybe those are the old pages that needs to be taken down or forwarding to the new pages.
Yi Y.
http://www.ni.com/support
Message 3 of 11
(5,048 Views)
Could it be that your browser security settings are too tight?
Message 4 of 11
(5,043 Views)
Thanks for the responses.  I followed Yi's links and they do work.  However, I happen to have the URIs from my original attempt, and they still don't work.  Here is an example, and proof Smiley Wink
ftp://ftp.ni.com/support/labview/windows/runtime/8.2/LabVIEW_8.2_Runtime_Engine.exe
Mon Sep 17 17:28:04 2007 Connecting ftp.ni.com:21
Mon Sep 17 17:28:04 2007 Connecting ftp.ni.com [IP=130.164.140.175:21]
Mon Sep 17 17:28:04 2007 Socket connected, Waiting for welcome message.
Mon Sep 17 17:28:04 2007 220 ftp.ni.com NcFTPd Server (licensed copy) ready.
Mon Sep 17 17:28:04 2007 USER anonymous
Mon Sep 17 17:28:04 2007 331 Guest login ok, send your complete e-mail address as password.
Mon Sep 17 17:28:04 2007 PASS ********
Mon Sep 17 17:28:04 2007 230-You are user #33 of 750 simultaneous users allowed.
Mon Sep 17 17:28:04 2007 230- *** Welcome to the National Instruments FTP Site ***
Mon Sep 17 17:28:04 2007 230-              ftp.ni.com
Mon Sep 17 17:28:04 2007 230-Important changes!
Mon Sep 17 17:28:04 2007 230------------------
Mon Sep 17 17:28:04 2007 230-As of January 23, 2004, /incoming will allow only uploads. Downloads from /incoming are not allowed.
Mon Sep 17 17:28:04 2007 230-You can download temporary files from /outgoing. Uploads to /outgoing are not allowed.
Mon Sep 17 17:28:04 2007 230-Compression Formats:
Mon Sep 17 17:28:04 2007 230--------------------
Mon Sep 17 17:28:04 2007 230-.hqx files are compressed using Binhex Mac and PC utilities.
Mon Sep 17 17:28:04 2007 230-.zip files are compressed using PKZip version 2.04g PC Utility.
Mon Sep 17 17:28:04 2007 230-.tar files are compressed using the UNIX "tar" command.
Mon Sep 17 17:28:04 2007 230-.Z files are compressed using the UNIX "compress" command.
Mon Sep 17 17:28:04 2007 230-.sea files are Macintosh Self-Extracting Archives.
Mon Sep 17 17:28:04 2007 230-      - National Instruments World-Wide Web Site:
Mon Sep 17 17:28:04 2007 230-                 http://www.ni.com
Mon Sep 17 17:28:04 2007 230-      - National Instruments FTP Site:
Mon Sep 17 17:28:04 2007 230-      - Developer Exchange Discussion Forums:
Mon Sep 17 17:28:04 2007 230-                 http://www.ni.com/exchange
Mon Sep 17 17:28:04 2007 230 Logged in anonymously.
Mon Sep 17 17:28:04 2007 Login Successful
Mon Sep 17 17:28:04 2007 REST 100
Mon Sep 17 17:28:05 2007 350 Will attempt to restart at position 100.
Mon Sep 17 17:28:05 2007 This site can resume broken downloads.
Mon Sep 17 17:28:05 2007 REST 0
Mon Sep 17 17:28:05 2007 350 Will attempt to restart at position 0.
Mon Sep 17 17:28:05 2007 TYPE A
Mon Sep 17 17:28:05 2007 200 Type okay.
Mon Sep 17 17:28:05 2007 PASV
Mon Sep 17 17:28:05 2007 227 Entering Passive Mode (130,164,140,175,228,74)
Mon Sep 17 17:28:05 2007 LIST /support/labview/windows/runtime/8.2/LabVIEW_8.2_Runtime_Engine.exe
Mon Sep 17 17:28:05 2007 550 No such file or directory.
Mon Sep 17 17:28:05 2007 TYPE I
Mon Sep 17 17:28:05 2007 SIZE /support/labview/windows/runtime/8.2/LabVIEW_8.2_Runtime_Engine.exe
Mon Sep 17 17:28:05 2007 550 No such file.
Mon Sep 17 17:28:08 2007 227 Entering Passive Mode (130,164,140,175,228,76)
Mon Sep 17 17:28:08 2007 RETR /support/labview/windows/runtime/8.2/LabVIEW_8.2_Runtime_Engine.exe
Mon Sep 17 17:28:08 2007 550 No such file.
Mon Sep 17 17:28:08 2007 RETR support/labview/windows/runtime/8.2/LabVIEW_8.2_Runtime_Engine.exe
Mon Sep 17 17:28:08 2007 Error occured!
Message 5 of 11
(5,027 Views)
Upon closer inspection of the URI, and comparing it to Matthew K's, someone at NI had transposed the path.  Just my luck!
Message 6 of 11
(5,024 Views)
Hi mrsharkbait,
Thanks for your report.  This indeed looks like a mistake on the website.  I'll file a report on that and the web team will look into fixing it.
Yi Y.
Message 8 of 11
(4,970 Views)
You can get all run-time engines here.
- Partha ( CLD until Oct 2027 🙂 )
Message 9 of 11
(4,934 Views)
There are two types of runtime engines, for example, for LabVIEW 8.2:
LVRunTimeEng.exe (32 Mb)
LabVIEW_8.2_Runtime_Engine.exe (94 Mb)
It seem the second one (the more complete run-time engine) has been systematically removed from the FTP site. Why is that?
Message 10 of 11
(4,832 Views)
