run time menu for row headers
Is there any way to have run time menu only for the row headers and not the whole of the table?
Ritesh
Message 1 of 10
(4,645 Views)
I think - no. But you can check the mouse position if rightlkicking on the table and enable/disable the runtime menue.
Message 2 of 10
(4,633 Views)
Hi Eugen Graf,
Thanks for your suggestion.
How to create events for Righ Click?
In the event menu i couldn't see any Right Click option.
Ritesh
Message 3 of 10
(4,615 Views)
Event Structure -> Mouse Down on Table Event -> Button
Message Edited by Eugen Graf on 09-25-2008 04:52 AM
Message 4 of 10
(4,611 Views)
Hi Eugen Graf,
Thanks again.
But, how to enable/disable run-time menu programatically?
I cant see any option like that in the Property Node of the Table.
Ritesh
Message 5 of 10
(4,600 Views)
Hm, you are right. I can't fing this property too. But probably you can discard right klick event like discussed in this topic:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=357409
Message 6 of 10
(4,596 Views)
Thanks Eugen Graf.
It Worked.  :smileyhappy:
Message 7 of 10
(4,588 Views)
Hi Eugen,
Ton's Dynamic Event Registration Nugget illustrated how to register and unregister for event dynamically. So if you implement your suggestion enhanced by Ton's Nugget it should be possilbe to prgramatically turn on/off the required functionality.
Thanks Kudos for help out Eugen!
Ben
Message Edited by Ben on 09-25-2008 07:41 AM
Message 8 of 10
(4,585 Views)
The 'Shortcut Menu Activation?' event allows you to discard the menu activation.
Ton
My LabVIEW Ideas
Message 9 of 10
(4,580 Views)
Wow! It's the best suggestion, Ton .
Thank you
Message 10 of 10
(4,574 Views)
